March 29, 201115 yr fortsatt vårutförsäljning! SAC (Thailand) Glow Master 300B integrerad förstärkare. Ett demoex av denna handbyggda Thailändska förstärkare. listpris : 25000:- vårt fyndpris : 10000:- pma vid intresse! Lasse Transient Design spec: Product Type : Stereo Vacuum Tube Integrated Power Amplifier with 5 RCA Input Pre-Amp/Input Tubes : 6N1P x 2 Driver Tubes : 5687 x 2 Output Tubes : 300B Electro Harmonix. x 2 Rectifier : 5U4GB Filter Capacitor ; 100+100uF Audiophile Grade Filter Choke : Low Loss 5H/250mA Coupling Capacitors : Hovland Musicap Signal Resistors : Kiwame Carbon Film type Output Transformer : SILK S-3250(Fi) Transformer 3.5K EI M6 core Output Power : 8 watts/CH class A1 Frequency Response : 10-100,000Hz (-3dB) at full power Input Sensitivity : 0.45V for full power output (at maximum volume gain) Overall Gain : 33dB THD + noise : Less than 5% at rated power S/N ratio : below 88dB Size : (W) 43 x (D) 37 x (H) 20 cm. Weight : Approx 22 kg.
