ORIGINAL RECORDING GROUP ger ut 10 eftersökta klassiska Decca titlar på 45 rpm
Presenting ORG Ultimate Edition 180gram, double 45rpm LPs! ORG is proud to present the ORG Ultimate Edition, a brand new series of great LP titles from the London catalog. Cut at 45rpm by Bernie Grundman on his newly upgraded mastering system and tube powered lathe, these LPs were pressed by RTI and sleeved in deluxe laminated gatefold jackets. They represent the very finest examples of the vinyl LP format available today.
Bernie Grundman's Updated Mastering System:
  • New customized dual mono power supplies
  • New tape pre-amplifier: an upgraded hybrid design with single-ended in-out that is specifically triode on the input for the gain and EQ and feeds into a discreet solid state circuit that drives the output
  • Brand new tape heads for the Studer playback tape machine including a complete hardwire with Cardas cables
  • The power supplies on tube cutter amps have been updated and rewired with Cardas cable on the head leads and feedback
  • The Studer in Bernie's cutting room is essentially transport only i.e. it is used for the superb stability of its mechanical parts. All the electronics (from the tape heads through to the cutting head on the lathe) have now been totally customized and hard-wired point to point
  • The tube cutting amps used for the ORG LP reissues have just been re-tubed with ex-US military grade tubes from Sylvania
Only 2500 Numbered Limited Edition Copies will be made worldwide and subscriptions are strictly on a first come, first serve basis. There is a very limited number of subscriptions available so reserve your copies today by becoming a subscriber! These great classical titles will be released one to two per month.
Titlarna är:
1. ORGLP0100-45 Albeniz / Suite Espanola
2. ORGLP0102-45 Falla / Three Cornered Hat
3. ORGLP0103-45 Brahms / Piano Concerto No. 1
4. ORGLP0104-45 Chabrier / Espana Vol. 2
5. ORGLP0105-45 Ravel / Daphnis et Chloe
6. ORGLP0106-45 Mendelssohn / Symphony No. 3
7. ORGLP0107-45 Bruch & Hindemith/ Scottish Fantasia & Violin Concerto
8. ORGLP0108-45 Mendelssohn/ Midsummer Night's Dream
9. ORGLP0109-45 Herold-Lanchberry/ La Fille Mal Gardee
10. ORGLP0110-45 Grieg/ Peer Gynt
Om ni inte känner igen skivorna från skivomslagen så är det samma inspelningar som getts ut åtskilliga gånger och då oftast med skivomslaget tagit ifrån engelska originalet ;)
Tyska Speakers Corner har gett ut alla på 33rpm/180g utom 2 st. som de gav ut som boxar på 45rpm (SXL 2246 & SXL 2313)
- De välkända skivomslagen är
SXL 6355 Albéniz: Suite Española - Rafael Frühbeck De Burgos/New Philharmonic Orchestra (London CS 6581)
SXL 2296 Falla: Three Cornered Hat - Ernest Ansermet/L'Orchestre de la Suisse Romand (London CS 6224)
SXL 6023 Brahms: Piano Concerto No. 1 - Clifford Curzon/George Szell/London Symphony Orchestra (London CS 6329)
SXL 2020 Chabrier: España - Ataulfo Argenta/London Symphony Orchestra (London CS 6006)
SXL 2164 Ravel: Daphnis et Chloé - Pierre Monteux/London Symphony Orchestra (London CS 6147)
SXL 2246 Mendelssohn: Symphony No. 3, Fingal's Cave - Peter Maag/London Symphony Orchestra (London CS 6191)
SXL 6035 Bruch & Hindemith: Scottish Fantasia & Violin Concerto - David Oistrakh/Jascha Horenstein/London Symphony Orchestra (London CS 6337)
SXL 2060 Mendelssohn: A Midsummer Night's Dream - Peter Maag/London Symphony Orchestra (London CS 6028)
SXL 2313 Herold-Lanchberry: La Fille Mal Gardee (utdrag) - John Lanchberry/Royal Opera House Covent Garden (London CS 6252)
SXL 2012 Edvard Grieg: Peer Gynt - Øivin Fjeldstad/London Symphony Orchestra (London CS 6049)
