Phonar Credo Reference
Tyska Phonar har äntlligen kommit ut med en helt ny högtalare. Credo Primus och Credo Optimus.
Dessa kombinerat blir Credo Reference!
Primus 42 400 :-
Optimus 52 500 :-
Reference
Info om Reference;
Element från Scan-Speak Illuminator
Frekvensomfång 25 - 29 000 hz
Bas: 2 x 180 mm
Mellan: 1 x 180 mm
Känslighet: 85 db
Impedans: 4 (Primus) och 8 (Optimus)
Dimensioner Primus: H400 x B240 x 341 mm
Dimensioner Optimus: H710 x B240 x 405 mm
Totalt vikt: 37 kg st
Valmöjlighet;
"A digital sound processor (DSP) in an external box which gives an professional options for a room and sound adjustment of the Credo Optimus woofer unit. Standard setups or though the information of a spot measurement all critical frequencies of the room can be equalised by the electronic crossover of the digital sound processor.
The usage of a DSP requires a Bi Amping drive of the Credo Primus and Credo Optimus"
Kostnad för Optimus DSP
54 000 :-
No posts to show
