January 2, 201016 yr En ersättare till 1.6 kommer att visas på CES; "The MG 1.7 is a departure from Magnepan's forty-year history of using planar-magnetic for the bass or lower midrange. The use of quasi-ribbon technology down into the lower midrange and bass will provide a new level of coherence. The MG 1.7 also boast a quasi-ribbon supertweeter with a wider "sweet spot [taking it] one step closer to the delicacy and detail of Magnepan's true ribbon tweetern. A new styling with wrap-around aluminum trim on the MG 1.7 is also a departure from Magnepan's more conservative cosmetic styling. The standard wood trims of the MG 1.6 are available upon special order" Mycket intressant för alla oss som har fastnat för det speciella Magnepanljudet och vi kan förmodligen även se fram mot ersättare till de större modellerna vad det lider
