For Immediate Release:
AMR CD-777 CD Processor is Launched
The Swan Song Philips Multi-bit Chipset; Eerily Close to Vinyl
London, U.K. 19th November 2009 AMR would like to announce the launch of its CD-777 Compact Disk Processor1. The CD-777 Premier Class CD Processor housed in an aircraft-grade pure aluminium-alloy chassis, is a complete CD source; transport or DAC. The musical performance is beyond reproach and sounds unerringly close to true analogue. At the heart is the exceptional and final, Philips Multi-bit2 Digital-to Analogue Converter chipset (which has not been used in a CD source until now). With NOS 6H1n-EV premium valves and an unwavering attention to power supply and components, the CD-777 comes into its own when compared to the best vinyl sources.
#1: First exhibited at the CES, Venetian Hotel, Las Vegas: January 2009.
#2: NOS Multi-bit refers to the fact that this chipset dates back to the 1990s, an era of Multi-bit chipsets designed and manufactured for performance (not profit).
Source: AMR
The Magic of the CD-777:s Philips Son of TDA1541A Multi-bit Chipset
AMR;s musical goals are Analogue, Musicality and Realism. At the heart of the CD-777 is the final, true Multi-bit chipset designed by Philips. Being the last Philips Multi-bit chipset (not the TDA1543 nor TDA1545A) before moving away from the Multi-bit technology, the erudite Philips engineers endowed this final chipset with a startling analogue character that is the magic of this chipset.
In terms of design, execution and sonic performance, this Multi-bit chipset is unmatched even by modern chipset designs and is second only to the original TDA1541A. Moreover, as this Philips chipset is rare and overlooked, it has not been used in a CD source until now.
Whether the CD-777 is used standalone or as a dedicated DAC (e.g. in conjunction with a computer or a CD transport), with the most organic, commanding musical performance, it remains the strongest digital source, on a par with the best vinyl sources.
1. Philips Last True Multi-bit DAC: this is the first time this New Old Stock true Multibit chipset has been used in a CD source and is worthy of the title son to the King of Multibit Philips TDA1541A chipset used in the multi-award winning CD-77. Producing visceral music, it is simply stunning. With AMR OptiSample, the CD-777 boasts full remote control of all sampling modes: Direct Mastering I&II (AMR custom Non-Oversampling modes), Oversampling (2X, 4X) and Upsampling (96kHz, 192kHz).
2. OptiUSB®: Fully Optimised USB Input: with the rapid rise of computer-based audio, AMR proprietary solution: OptiUSB® allows the CD-777 to become a dedicated CD-Transport or Digital-To-Analogue Converter through either USB or S/P-DIF without a commensurate rise in jitter which is unusual. The result is external or computer-based audio at the level of direct CD playback.
3. OptiValve®: Having the ultimate in digital execution would count for little if the analogue section was not just as dedicated. The analogue section of the CD-777 utilises AMR OptiValve® analogue stage with zero negative feedback and NOS 6H1n-EV valves (the EV designation denotes the premium version). This is a major factor behind the CD-777 organic and vinyl-like" performance.
4. OptiTrans®: dedicated transformers. AMR has shunned the mainstream (and more cost-effective) approach to the use off the shelf transformers, preferring to specify dedicated, hand-made transformers. Power supply is an integral part of circuit design and AMR steadfast approach yields the highest quality of power supply.
5. OptiDrive®: The OptiDrive® transport mechanism is an in-house, ground-up design. The musical synergy was made possible through using the best genuine components - the high-precision, reliable Sony K-series laser pickup mated to the musical Phillips CD-18 servo system along with a proprietary high-torque direct-drive motor. The software is bespoke by AMR to extract the maximum performance.
The worldwide recommended retail price is EUR2,999 (excluding VAT) for the CD-777 Compact Disk Processor.
For the CD-777 Specifications, please click on this link:
http://www.amr-audio.co.uk/html/cd777_specifications.html
To read the CD-777 Manual, please click on this link:
http://www.amr-audio.co.uk/html/UserManual.html
About AMR
Abbingdon Music Research (AMR), a subsidiary of the Abbingdon Global Group, is a multiple award winning high-end audio equipment company. AMR is a manufacturer of high fidelity equipment for the consumers and enthusiasts. Products include CD processors, phono equaliser, amplifiers and loudspeakers. Founded in the Great Britain, presently AMR has distribution in more than 20 countries. For more information on AMR, please visit www.amr-audio.co.uk
If you would like more information about this or any other topic, please e-mail Vincent Luke at
vincentl@amr-audio.co.uk
Note to journalists: High resolution photos and official logos may be downloaded from:
http://partnerdownload.amr-audio.co.uk/ProductPictures/
Guest patrikcaesar
Source: AMR
About AMR
Läckert med så många valmöjligheter :mm:
