Guest justaudiomagic Posted August 6, 2009 Posted August 6, 2009 Nu har vi äran att kunna erbjuda Proburn! Proburn är en kabelinbrännare; Cable burn-in: an acknowledged problem in need of a better solution. It is a well-known fact that high-quality audio and video cables improve over time when used in a hi-fi or home cinema system. A hard, closed-in sound with a distinct lack of bass are the qualities most noted when a cable is new; a cable that has been ‘burned-in’ will sound more open, extended and three-dimensional, with a more natural, less sterile performance overall. Unfortunately, most high-quality specialist cables only get close to realising their full potential after months of use. Playing wide-bandwidth music gradually improves the performance of speaker and interconnect cables, yet technically they will never reach optimum performance with music signals alone. The problem is quite simple. Real music has very little high-frequency energy, and thus will have a limited ability to improve a cable. Research shows that musical instruments may produce energy above 20kHz, but there is little sound energy above 40kHz. Also, most microphones do not pick up sound at much over 20kHz. Furthermore, even the best burn-in CDs have a limited effect, owing to the limited frequency range of a CD player. A typical CD player has a sampling rate of 44.1kHz (Red Book standard). Digital theory (Nyquist) suggests a maximum frequency of 22.05kHz; the highest frequency is always half the sampling frequency. In reality, 20kHz is about the maximum because of the need to filter within the replay device. Therefore, while it is accepted that sound, be it composed music or carefully generated frequencies played through an audio system, will improve a cable’s performance over time, it must also be accepted that the overall effect is limited technically. Cables conditioned in this way will never reach their true performance potential. Thus, an alternative method is required. It is critical to not only concentrate on the conductor, but also the dielectric. Ideally, cable burn-in needs to force electrons into all areas of the cable; this is something that simply playing music through an audio system can never achieve. The Proburn cable burn-in accelerator from Blue Horizon not only dramatically reduces the burn-in time of all cables, but also fully prepares them like no music ever can. Proburn does more than simply synthesise music; using specially-developed technology, the unit generates a sequence of unique ultra-low frequencies to penetrate the core of the conductor, and ultra-high frequencies that penetrate both the conductor and the dielectric. Using conventional methods, it’s extremely difficult to condition the dielectric of a cable, yet this is exactly where effort should be focused. Using carefully controlled energy levels and frequencies, electrons are forced and attempt to enter the dielectric. Imagine a high-frequency, high-energy force zipping along the conductor surface in a corkscrew fashion between the conductor and into the dielectric; the malingering electrons and negative charges are then forced to join the procession. Through this technique of ultra-low and ultra-high frequencies in a musical synthesis, the cable is fully prepared and burned in within 24 to 48 hours. This guarantees total penetration of the core of the cable, and also that the interface between the outer conductor surface and dielectric is fully and properly conditioned. This patent-pending technique fully prepares cables for audio or video use in a way that no amount of music ever can. To put this into context, Proburn produces 10,000 times the upper frequency limit of a typical CD player, which not only dramatically reduces the burn-in time for new cables but also fully prepares and conditions your existing cables. Proburn will also keep your cables performing to their full potential; condition them for 24 hours every six to eight weeks and your cables will remain free from negative charges and static problems. Priset är 8250 :- Quote
Guest justaudiomagic Posted August 6, 2009 Posted August 6, 2009 Intresserade kan läsa i Manualen här Quote
