For Immediate Release:
AMR FUSES REALISE FULL SYSTEM POTENTIAL
AMR Gold Fuses Outclass Generic Fuses to Unlock the Full Potential of All Audio and Visual Systems
London, 18 June 2009 - AMR has launched a range of Gold Fuses that are premium replacement fuses for all electronic products: audio and visual products from amplifiers to LCD televisions will attain a higher level of performance.
Source: AMR
The Generic Fuse
Traditionally, one of the weakest points in any typical component is the fuse. This is because standard electrical fuses do not take into account the needs of a high quality audio or video system as they are typically made from:
1. Thin glass tube body: microphonic issues
2. Low-grade metal spiral wire: microphonics, added inductance and power degradation issues
3. Low-grade metal end caps: poor contact, power degradation issues
The AMR Gold Fuse
AMR#8217;s Gold Fuse was developed after lengthy testing and auditioning. The Gold Fuse has been independently tested in the audio and visual fields against the leading brands and proved to be one of, if not the best, fuse currently available to the performance-minded consumer.
To an audio or visual system, the AMR Gold Fuse will bring the following improvements:
* Fuller body, better definition and detail
* Reduced distortion
* Extended dynamic range
AMR Gold Fuse Specifications:
* Silver alloy fuse wire, non-spiral, low inductance design
* Special non-magnetic, shock resistant anti-resonant ceramic body
* Gold-plated end-caps (Gold does not oxidise like Silver, hence better long-term reliability)
* 0.125A/0.25A/0.5A/1A/2A/5A/10A (further values to follow)
* Approval: UL SA PSE CE CCC
The worldwide recommended retail price is EUR35 (excluding VAT) for a pack of 3 fuses.
About AMR
Abbingdon Music Research (AMR), a subsidiary of the Abbingdon Global Group, is a multiple award winning high-end audio equipment company. AMR is a manufacturer of high fidelity equipment for the consumers and enthusiasts. Products include CD processors, phono equalizer, amplifiers and loudspeakers. Founded in the Great Britain, presently AMR has distribution in more than 20 countries. For more information on AMR, please visit www.amr-audio.co.uk
If you would like more information about this or any other topic, please e-mail Vincent Luke at
vincentl@amr-audio.co.uk
Note to journalists: High resolution photos and official logos may be downloaded from:
http://partnerdownload.amr-audio.co.uk/ProductPictures/
#12288;
This e-mail is from Abbingdon Music Research, a member of the Abbingdon Global Group. This e-mail may contain privileged and confidential information. It is intended for the named recipient(s) only. If you are not an intended recipient, please notify us immediately (by reply e-mail) and delete this e-mail from your system. We use third-party service providers to filter spam and provide other technical support for our electronic communications. All such third parties are required to implement appropriate security measures to protect our electronic data.
Då vi var och besökte Caroli Musik i Malmö så gav jag bort några av dessa säkringar till butikskillarna samt ett par kollegor som var på besök. Dagen efter så var det flera av dessa som plötsligt ville ha ännu fler efter att ha provat dem...
Akkelis Audio har dessa i lager för omedelbar leverans i följande värden: 0.125A/0.25A/0.5A/1A/2A/5A/10A
Pris 399 Kr för 3 st
Mvh Lasse
Jag hittar ingen information om den fysiska storleken på säkringarna: är de små 5x20mm eller stora 6x32mm - jag har uteslutande de stora som också av naturliga skäl har större kontaktyta....
//Eliot
  • 4 weeks later...
Hej Eliot!
Hoppsan, du har rätt! Det står inget om den fysiska storleken på säkringarna i AMR:s press-material. Men svaret nedan fanns att hitta på AMRs hemsida under FAQ:
"Presently, 5 x 20mm is available for internal component use and/or the IEC connector at the rear of the component. This size is commonplace in European equipment.
In the near future, 6.3 x 32mm which is popular in US equipment and the 6.4 x 25mm fuse which is mainly suited to UK mains electrical systems, will also become available."
Så det finns snart hopp även för dig att prova dessa! Listan på nöjda kunder som nu köpt och provat säkringarna växer fort!
Mvh Lasse
