calle_jr Posted June 25, 2009 Posted June 25, 2009 ** S Å L D A ** Överväger att byta förstärkare och säljer därför mina Cayin 860 monoblock Egenskaper: 2 RCA-ingångar Triod & Ultralinjär output mode switch 4, 8 & 16 Ohm högtalarutgångar IEC nätbrunn Specifikationer: Effekt (8 ohm): 70W (Ultralinjär), 38W (Triod) Frekvensomfång: 20Hz-35kHz +/-1db THD: 0.8% S/N Ratio: 90dB Ingångskänslighet: 600mV Ingångsimpedans: 100 kOhm (RCA) Utgångsimpedans: 4, 8 eller 16 Ohm Effektförbrukning: 260W Vikt: 2x22 kg Mått: 310x200x360 mm (BxHxD) If you love the luscious, warm, rich, textured sound that only tubes can optimally deliver, then you need to explore this Cayin line of power amplifiers. These 860 amps are hand-built and feature point-to-point wiring. Each of these monsters weighs in at over 40 pounds. This is classic, heavy-duty tube gear. Like all Cayin products, the 860 boasts: Hand made point-to-point wiring and workmanship better than any product at its price range. Heavy gauge-vented chassis with an automotive lacquer finish to ensure a solid platform and elegant look. Potted toroidal power transformers known for their lower stray magnetic fields that enables them to run cooler and quieter (no hum). Soft-start circuit (30 seconds) and conservative design runs the tube easy and powers it up gently for extended tube life. Tube plate fuse protects the amp output stage. Premium parts, including chassis-mounted ceramic tube sockets, ALPS volume control, Nichicon and Realcap capacitors, WBT style speaker terminals and Gold-plated input jacks. Aeronautics quality control standards. 1 week continuous factory burn-in to ensure quality. Samtliga originalrör bytta. Nuvarande rörtyper: Matchade quads Svetlana SED Winged "C" KT88 JJ ecc802S, JJ ecc803S, Ryska "military grade" 6H6P Komplett med originalkartonger och manual. http://www.cayin.de/ev_860.htm http://www.openair-speaker.de/Produkte/Pag...ayin/cayin.html Pris: 17.ooo:- Kan provlyssnas i Malmö. Frågor via PM, mejl eller tfn 0705-494349. Bilderna är nyligen tagna på mitt par: Quote
