Guest justaudiomagic
Nu har Dared kommit med rykande färska nyheter!
Två nya integrerade plus en flerkanalsförstärkare.
I20
MAX OUTPUT POWER:20W*2
FREQUENCY RESPONSE:20-20KHZ(±1dB)
DISTORTION:≤1%
SIGNAL TO NOISE RATIO:≥86dB
INPUT SENSITIVITY:225mV
INPUT IMPEDANCE:80Kohm
INPUT CHANNEL:LINE1,LINE2,LINE3,AUX,USB/DAC
OUTPUT:4Ω/8Ω,6.35 headphone output
WEIGHT:13.0Kgs/set
TUBES USED:6P3P(6L6G)*4,12AX7*2,12AU7*2
I30
MAX OUTPUT POWER:30W*2
FREQUENCY RESPONSE:20-20KHZ(±1dB) DISTORTION:≤1%
WEIGHT:13.0Kgs/set
TUBES USED:EL34*4,12AX7*2,12AU7*2
DV-6C
POWER VOLTAGE: AC115V/230V 50-60HZ
Max Output POWER: 6*65W(4Ω)
INPUT:
AUX
5.1 input:Front(L),Front®,Surround(L),Surround®,Centre,Sub-woof
Output Mode:(5.1),(5.0),(2.1),Stereo
Sub-woof:-60db~60db
Front:-12db~12db
Surround: -12db~12db
Centre: -12db~12db
Master Volume: -60db~60db
FREQUENCY RESPONSE: 20-22KHz
DISTORTION:≤1% (55W 1KHZ 4Ω)
SIGNAL TO NOISE RATIO: ≥88dB
INPUT IMPEDANCE:47KΩ
SIZE: L350 X W190 X H150 mm
WEIGHT: 6.0Kgs/set
TUBES USED:6N2x3
Snygga och intressanta!
Men, som vanligt, pris? Vad kostar de?
(Och varför ska det vara så svårt att skriva priset i annonsen redan på en gång...?)
Cheers :) / stargazer
  • 1 month later...
Teaser! Info o priser kommer inom kort
VP-30P
VP-2A3P
VP-80P
VP-99P
I20 -> 11 900 :-
I30 -> 13 900 :-
