SP-Technology
Nu har vi åter fått ÅF för de vackra o välljudande SP-Tech!
Timepiece Mini
Timepiece
Continuum AD MKIII
Continuum 2.5 MKIII
Revelation MR-1 MKIII
Hej
SP-Tech kan fås i följanda finisher;
Studio Finish
*Solid Oak front, top & bottom & Oak veneered side panels with Black Finish.
*Neutrik “Speak-On" input connectors.
*Mundorf crossover components.
*R. A. Smith Ltd. Copper Internal Wiring
Standard Finish
*Solid hardwood front panels w/ choice of (3) species.
*Matching veneer species on sides
*Satin Finish.
*Mundorf Copper Binding Posts
*R. A. Smith Ltd. ä Copper Internal Wiring @ No Charge.
Priserna uppifrån ner;
Timepiece Mini -> 2995 $
Timepiece 3.0 -> 5495 $
Continuum AD MKIII -> 8995 $
Continuum 2.5 MKIII -> 14 995 $
Revelation MR-1 MKIII -> 19 995 $
Timepiece Mini
Impedance 8-Ohms
Sensitivity 87dB@1W/1M
Frequency Response (anechoic) 42Hz-22KHz +/- 2dB
-3dB Points (anechoic) 40Hz & 24KHz
Bass Alignment Proprietary 4th order Hybrid Reflex
Power Handling (Long Term) 100 Watts (I.E.C. 268-5)
Power Handling (Short Term) 250 Watts (I.E.C. 268-5)
Crossover Type 4th order L-R Acoustic @ 800Hz
Dimensions 16.5"H x 9.5"W x 12.75"D
Weight 38 lbs. Each
Timepiece 3.0
Impedance 8-Ohms
Sensitivity 85dB@1W/1M
Frequency Response (anechoic) 30Hz-22KHz +/- 2dB
-3dB Points (anechoic) 30Hz & 24KHz
Power Handling (Long Term) 125 Watts (I.E.C. 268-5)
Power Handling (Short Term) 300 Watts (I.E.C. 268-5)
Crossover Type 4th order L-R Acoustic @ 600Hz
Dimensions 21.5"H x 12.5"W x 15.75"D
Weight 65 lbs. Each
Continuum AD MKIII
Impedance 4-Ohms
Sensitivity 88dB @ 1W/1M – 91dB @ 2.83V/1M
Frequency Response (anechoic) 35Hz-22KHz +/- 2dB
-3dB Points (anechoic) 32Hz & 24KHz
Power Handling (Long Term) 250 Watts (I.E.C. 268-5)
Power Handling (Short Term) 600 Watts (I.E.C. 268-5)
Crossover Type 4th order L-R Acoustic @ 700Hz
Dimensions 30.75"H x 12.5"W x 15.75"D
Weight 85 lbs. Each
Continuum 2.5 MKIII
Impedance 4-Ohms
Frequency Response (anechoic) 25Hz-22KHz +/- 2dB
-3dB Points (anechoic) 24Hz & 24KHz
Dimensions 53.75"H x 12.5"W x 15.75"D
Weight 163 lbs. Each
Impedance 4-Ohms
Bass Alignment Proprietary 2nd order Optimized
Transmission-Line
Dimensions 66.75"H x 12.5"W x 21"D
Weight 200 lbs. Each
