Guest justaudiomagic
Vi kommer inom snart även rikta in oss på diy-marknaden för er som hellre bygger själv eller kanske vill bygga om filtret i era nuvarander högtalare med bättre komponenter etc etc.
Vi kommer saluföra 10 olika kondensatorer, som t ex ClarityCap SA;
"Specially developed to meet the needs of the professional audio engineer in both hi-fi and studio monitoring, these components are the result of extensive consultation between the audio industry and ClarityCap. The capacitors are hand wound using a 10µm(630Vdc) rated polypropylene film. Following a special heat treatment cycle, insulated copper terminals are hand soldered to give the best possible connection. The inherently low dissipation and dielectric absorption factors of polypropylene allied with an excellent mechanical stability results in an extremely detailed sonic performance.The construction also results in a low self-inductance and ESR and the devices are highly stable with regard to temperature and frequency."
Två olika spolar;
Aircoils och Core Inductors
Sen även självklart motstånd!
Vänligen!
  • 2 months later...
Nu kan vi även stolt presenter hela sortimentet av WBT och subwoofer-förstärkare i "DIY-Hörnan"
  • 4 weeks later...
Nu har vi äran att presentera det bästa av det bästa när det gäller spolar! Jantzen Royal Silver. Dessa är så nära "Ideal Inductor" man kan komma.
Jantzen egna ord;
"Our Silver coils are made from pure silver foil, AG 99,97 %. A Polypropylene film separates the windings. Coils are wound on a hard-wood core. Available in 16 AWG (1,33 mm). Because of the very tight windings, we have achieved an extremely low magneto shrinking factor and virtually zero FM distortion. Jantzen Silver Coil is even closer to the "Ideal Inductor" compared to our famous Cross Coil made from copper foil. We guarantee the tolerance +/- 1 %. This product is designed for the very best high-end loudspeaker systems. Jantzen Silver Foil Coil 16 gauge sustains 350 watt RMS."
