Vi vil gerne vise nogle af de produkter vi distribuerer i Sverige.
De fleste af vore produkter distribuerer vi i hele Skandinavien, og søger flere Äterförsäljare i Sverige
En lille udsnit.
Vi har fået et nyt agentur i hele skandinavien
Herron Audio
Rør grej fra USA med et vældig fint reputation, finish og ikke mindst en meget fin lyd.
Alle pre amps kan invertere AC power forbindelsen og VTSP (pre amps) kan inverterer indgangene, så har man en mulighed for at lytte sig frem til indstillingen for den bedste lyd.
VTPH-2 phono stage med rør til MM og MC
forstærkning 64 og 69 dB (MC)
Impedansen for MC kan justeres med disse indsats RCA.
kan leveres med sort eller sølv frontplade, her i sort
bagsiden
VTSP-2 og VTSP-3 Pre amp
Fuld fjernbetjent and volume, indgange og mute
fuld rørbestykket
her vist med sølv front
"The overall and distinctly noticeable effect has been to make listening to music more enjoyable and another step closer to realistic. For music lovers that may be all that needs to be said."
"It is time for some serious listening to be done. I am not going to give you a litany of recordings to try to show off some specific aspects of this newest Herron creation. That is not where the appeal of this music reproducer lies. It lies in making your experience with listening to a favorite recording more satisfying than ever before. The fact that it has a tad (a southern word meaning a little bit or definite hint) more bass fullness, richness and power in the mid to upper bass is only a part of overall experience and does tend to reveal its vacuum tube heritage. The audibly extended high frequency response has its own attraction at the same time being silky smooth and sweet while revealing even more inner detail. That is a really tough balancing act for an audio designer to successfully accomplish. It also appears to be more extended and very definitely adds the natural sensation or feeling of the recording location and strong hints of its size! That is probably at least partly responsible for the added detail as is the seeming lack of background noise. This is a very quiet preamplifier and listeners may find it even quieter in the lower gain mode."
"The all-important mid-range extends from its lower reaches adds detail and presence to the bass, to its upper extremes giving body to beautiful harmonic overtones is where music lives. The Herron vacuum tube VTSP-3 preamplifier makes that all important range come nearly alive, and the better the recording the closer it comes and the more the music will be savored, enjoyed and appreciated. It is as if the listener is moved a few rows closer to the orchestra compared to the previous VTSP-2. I must award Keith Herron's model VTSP-3 preamplifier my highest possible recommendation and hope that many music lovers will have the opportunity to discover it for themselves."
- Karl Lozier Positive-Feedback Online Issue 35
A highly refined advancement over the VTSP-2 with the addition of a precision non-resonant plate voltage controller, two front panel selectable gain modes for system matching and improved tube circuitry for increased resolution.
Note: The VTSP-2 can be factory upgraded to a VTSP-3.
Power amp - mono blok
150w i 8 ohm - 275w i 4 ohm
Andre af vore produkter
Miyabi cartridges
Kan leveres i en mono version, og en custom version fra MIYABI designer, Mr. Haruo Takeda
Pick-up vægt nyt design i aluminium (pris og leveringstid kommer)
vi har stadig denne til 750 Skr./stk.
Amazon - turntables
model 1
model Referenz
Vi udarbejder gerne tilbud på pladespiller kombo med tonearme og pick-ups.
Sota - turntables www.sotaturntables.com
Trichord Research - RIAA & electronics www.trichordresearch.com
Dino mk. II: nu i sort
Diablo:(her vist med NC PSU)
D300 300w i 4 ohm kl. D MONO power amplifier med NC PSU
Tri-planar mk. VIII (eller mk. VIIi) tonearms www.triplanar.com
Audiostatic fullrange electrostatic speakers
can deliveres in passiv and in a amplifiered version.
For bas freaks subwoofer electrostatic version
se vores brugt tilbud:
enter High End Sound web for brugt tilbud
SEND VENLIGST EMAIL TIL VORES ADRESSE ikke gennem Euphonia
med venlig HIFI hilsen [:)]
Gert
www.highend-sound.com
info@highend-sound.com
+45 40 70 16 14
