Full-Featured Tube Preamp and Headphone Amp
Enjoy the highly musical sound of SET (Single
Ended Triode) EL84 vacuum tubes in an exquisitely
built dual port headphone amplifier from DOGE.
And as a bonus, you can choose both #8220;Normal#8221; and
#8220;Music Hall#8221; sound quality.
Choked full a features
The Doge 6210 has features that you would expect
in s a state-of-the-art headphone amplifier. Two
EL84 tubes and two 12AX7 tubes make up the gain
stage. A switch lets you chose between #8220;Normal#8221;
and #8220;Music Hall #8220; sounds. The unit comes with two
headphone jacks. Chose headphones with 60, 300
and 600 ohms. There is also a #8220;line out#8221; that allows
the unit to be used as a preamp.
Rock solid Build Quality
The point-to-point wiring used throughout the DOGE
6210. Excellent caps and resistors are chosen. This
is an all tube model and there are not any semi
conductors used in the signal path. Transformers
are hand-wound types manufactured by DOGE and
used exclusively in their amps, preamps and CD
players.
The Sound
The Doge 6210 has presents a smooth sound
stage with a variety of headphones: Grados, Beyers
and AKGs. Which to our knowledge was
remarkable. The best part was the low end on all
these phones where organ pedals and the
dynamics of kick drums was formable. The
midrange blooms into the phones and pushes
images out in front of you. Over all, very smooth
timbre form bottom to top.
Specifications:
Output Power: 0.5 watts / channel
THD: < 1% @ .5 watts, 1kHz < 0.2% @ 0.1 watt, 1 kHz
Output Impedance: 60, 300, 600 ohms
Input Impedance: 50K ohms
Input Sensitivity: 0.5v
Frequency Response: 20 = 20 kHz @ +/- 1db
För den som vill veta mer...
http://www.head-fi.org/forums/showthread.php?t=219249
Nypris: 700$ + frakt/tull/moms
Kan ses och höras i hemmiljö på Hisingen/GBG (Bjurslätt)
Säljes för 3500:- (Eventuellt byte mot vibrationsdämpning, vinylgrejjer, shaktistones eller något annat kul.)
Frakt, hämntning eller leverans sker efter överenskommelse.
oralinkontinens@hotmail.com
Ej till salu längre!
Edited by drbob
