Wolfgang Posted October 28, 2005 Posted October 28, 2005 Efter mässan har vi lyckats få ett ännu bättre pris på music hall mmf-5 turntable The music hall mmf-5 turntable is a 2-speed belt driven audiophile turntable employing the unique dual-plinth sandwich-style construction originated by music hall. The distinctive design isolates the critical sound reproducing components; platter, main bearing, tone arm, and cartridge on the top platform from the motor, switch, wiring, and feet which are mounted on the bottom platform. Six viso-elastic cones separate the two platforms and provide vibration damping. The mmf-5 comes complete with cartridge mounted Features: • music hall’s unique dual-plinth sandwich-style construction • Low noise fully manual belt-drive design • Separately isolated asynchronous motor with two-speed (33/45rpm) pulley • Goldring 1012GX moving magnet phono cartridge ($225 value) with replaceable fine line Gyger II diamond stylus. The cartridge supplied is properly aligned and mounted • High precision stainless steel bearing sheathed in Teflon for noise-free fluid operation • Metal screw-on record clamp • Glass platter with soft felt mat • Compliant feet and round spirit level • High quality gold RCA connectors Dimensions • Dust cover and 45rpm adaptor W18.25 x D13.25 x H5.5 in. • Excellent instruction manual and easy assembly Weight: 12 kg Pris: 7.995:- Vi kommer också att ha MMF7 och MMF9 innom det snaraste!! Det "rördrivna" Bellari Riia´n / hörlursförstärkaren kommer vi att erbjuda för sagolika 2.800:- PM´a eller maila Quote
