Fick idag in en ny modell till lagret från Hifiman: DEVA PRO!
Det mest är nytt och bytt och uppdaterat mot innan:
- Stealth Design på magneterna för en ännu mer transparent upplösning av ljudet
- Dubbla ingångar för kabel
- Förbättrad DAC i den medföljande BlueMini blåtands-mottagaren
Pris 4200kr till kund.
The new DEVA Pro picks up where its predecessor left off, offering full-range, audiophile-grade sonics, whether listening via wired or via Bluetooth. The new model builds on the value of the original by incorporating two recent HIFIMAN developments : Stealth Magnet technology and Himalaya R2R DAC (digital to analog) architecture.
HIFIMAN’s Stealth Magnet technology dramatically reduces wave diffraction turbulence that degrades the integrity of the sound waves, maximizing the accuracy of the sonic output.
Packaged with the DEVA Pro, the Bluemini is now equipped with our own DAC chip the HIMALAYA : a chip composed of an array of resistors with a new algorithm that reduces power handling between the chip and peripheral components. As a result, signal-to-noise ratio, total harmonic distortion, and energy consumption are at their most efficient and cost-effective.
The Bluemini dongle supports high-resolution codecs such as LDAC and aptX-HD, making it well-suited to most currently available high-definition streaming devices. Playback time is 8 hours.
The Bluemini R2R dongle can be used as a powerful integrated DAC/amp for audiophile-grade performance from smartphones and other low-power devices simply by connecting a USB-C cable.
The Deva Pro also features dual sided connectors allowing it to be used with a much wider range of cables.
Deva Pro specifications :
Frequency Response : 20Hz-20kHz
Impedance : 18Ω
Sensitivity : 93.5dB
Weight : 360g
1 hour ago, Transient Design said:
Är inte det här en märklig produktbild? Eller har jag inte fattat?
För mig är en 3.5mm TRRS en fyrpolig 3.5mm-kontakt?
Äh, det klarnade! Man kan använda en balanserad kabel med EN anslutning i luränden av typen TRRS, men är då hänvisad till den vänstra lurens uttag. Traditionell kabel med två kablar av typen TRS kan anslutas till respektive lur.
Ja! Exakt. Detta är en lösning för att kunna använda nya Deva PRO med Hifimans balanserade kablar (samma som till Sundara mfl) med dubbla anslutningar men ändå driva båda lurarna från ena sidan med en BluMini blåtandsmottagare. Detta var ju ett av problemen med den äldre modellen att den inte upplevdes lika "hifi" som tex Sundara med vilken den delar mycket av tekniken. Och i Sverige så är det helt tydligt så att kunder är pålästa och kunniga och vill ha det bästa ljudet för pengarna. Nu i den nya Deva PRO så slipper man välja! Ha kvar kakan och äta den samtidigt! :-) Smidighet med bluetooth när man springer omkring och dammsuger eller lagar mat och när barnen väl har somnat sig så kan man finlyssna en stund i lugn och ro...
