thli72 Posted August 11, 2021 Posted August 11, 2021 Eftersom jag gjorde en tråd om Nordost nya serie känns det mest rättvist att även göra en om G6 Från klassiska Transparent Cable. TRANSPARENT GENERATION 6 | Transparent Audio (transparentcable.com) " By virtue of a totally new measurement metric, the just released Transparent Generation 6 represents a higher level of refinement and precision to the Transparent Audio Cable design model. This new metric not only ensures that every customer will be able to fully realize the design model advancements of the past 6 years, but each product in the audio cable line-up now embodies a demonstrative evolution of the Transparent musical standard. Generation 6 also heralds a new and more comprehensive approach to using different types of advanced materials and more mass to eradicate resonant frequencies from within and from without network enclosures. In addition to a more solid foundation for the music’s lowest frequencies, the listening result of removing vibration and resonance is a quieter sound field with low-level information retrieval that is capable of revealing previously hidden “you are there” details. Although every Transparent Audio Cable benefits from the cumulative efforts of our research and development over the past 6 years, it should be no surprise that the new Generation 6 CONNOISSEUR COLLECTION leads the way in terms of redefining yet another great leap forward." Toppmodellen Magnum Opus G6 som kostar över miljonen men då får du den i valfri längd mellan 2,4-4,5m och hemleverans och installation ingår Quote
Tyking Posted August 18, 2021 Posted August 18, 2021 Hej. Någon som haft möjlighet att lyssna på G6 och ev jämföra med äldre Transparent? Mvh Tyking. Quote
AlfaGTV Posted August 18, 2021 Posted August 18, 2021 Jag tycker det ser ut som om Batmans Batmobile numera kommer med laddsladd? Bebop and ulfsan 2 Quote
LPL Posted August 18, 2021 Posted August 18, 2021 36 minutes ago, AlfaGTV said: Jag tycker det ser ut som om Batmans Batmobile numera kommer med laddsladd? Jag fick samma association när jag såg kabeln. Designen kanske ska ge sken av att kabeln har superkrafter eller akustiskt optimerad med lågt luftmotstånd Quote
