Innuos släpper sitt OS2.0
octavia rs
On 2021-08-03 at 20:55, plind said:
På Innuos Sense appen är jag inloggad på Tidal via ett Squeezeboxkonto(Logitech) men annars har jag mitt vanliga Tidalkonto med eget användarnamn och lösenord..
Innuos är på gång med en integrerad lösning av Tidal likt Qobuz är idag, står en del om det i veckobrevet som kom igår även lite bilder på hur det kommer se ut.
https://innuos.com/2021/09/15/weekly-update-15th-sep-2021/
  • 3 weeks later...
  • 9 months later...
Innuos har släppt version 2.1.1 med ett par buggfixar.
Bug Fixes
Fixed an issue where TIDAL playlist only displayed 30 tracks, although the entire playlist was played
Fixed an issue where Qobuz tracks in the player queue were displaying the incorrect album cover
Fixed an issue where after the update, the new music section would not preserve the original order
Fixed an issue where the player, when in full screen, would stop the progress in specific conditions
  • 1 month later...
Innuos släppte version 2.2.0 igår, lite nya funktioner och buggfixar. Uppdateringen fortlöpte som vanlig utan problem fick dock göra en omstart av servern efter uppdateringen för att den skulle hitta min DAC via USB.
New Features and Improvements
  • Search and Edit Artist Information
  • Search New Album Data
  • On import, fetch album cover from online services if album does not have cover metadata
  • List images present in the same folder as album on Change Cover
  • Show alternative covers on an Album
  • Display PDF Booklets
  • Allow user to more easily play a single track from an album or playlist
  • Sense Standalone and Endpoint Modes
  • HQ Player Endpoint Mode
  • Faster performance editing long playlists
Fixes
  • NAS shared folder does not rescan when folder name has square brackets
  • Playlist stuck on infinite spinner
  • Back button on navigation not working properly in some screens
  • Volume window does not close when clicking outside of available players box
  • Only favorited albums displayed with Favorite Filter turned OFF
  • Scroll index is wrongly shared by pages on different tabs
  • Albums on 'Appears On' page disappear in browser after getting back page focus
  • Search Results show duplicate albums
  • Changing browser window triggers player reconnecting
  • Setting a streaming album, playlists and tracks as favorite disappears after logging out and logging in
  • Factory Reset does not clear History
  • Player shows last connected player when no players are available
  • Play Anything button appears in the player even if there is no DAC
  • Play Smart Mix button is hidden when screen is smaller than 600px width
  • Playlist covers are not working properly
  • Active filters overlap albums when screen is smaller than 525px width
  • Play icon in playlists track list disappears
  • Folder View freezes and player is stuck on infinite
  • Other small bug fixes and performance improvements
Detta är lite för spännande för att jag skall låta det vara oprövad. Min Holo
Audio May DAC i NOS läget tycker om DSD 256 och PCM i höga samplingsfrekvenser. Skall bara samla kraft till att testa detta. HQ player är längst ned på skalan för användarvänlighet.
jag reagerade också på denna punkten. jag tycker det är kul att Innuos tillgodoser en relativt nischad målgrupp och ger sina användare valmöjligheter. kul att HQPlayer användare får fler endpoints av hög kvalité att välja på, Statement användarna kanske inte riktigt är den tilltänkta målgruppen i första hand, men kanske gör det de nya PULSE/PULSAR modellerna lite extra intressanta för en del.
för att få ut maximal effekt av HQPlayer och kunna använda några av de mest krävande filtrena så behövs det ett rejält tilltaget kraftpaket till server dock, men man kan ju alltid börja med att testa enklare varianter för att se om det är något som lockar att fortsätta med, som du säger så lämnar ju klienten lite i övrigt att önska, inte minst om man är van vid Innuos eller Roon sedan tidigare. beroende på hur enkelt det är att switcha (eller om HQPlayer läget alltid är aktivt?) så kan man ju alltid använda det för "finlyssning" eller så.
Jag har en hyfsat kraftig spelrigg (som bara står oanvänd) med Intel 12700K i7 och RTX3080 kort i som borde kunna klara av DSD256/DSD512 utan större bekymmer.
Undrar bara hur det blir med en Phoenix Net i kedjan då den har bara 100mbit ut. Nåväl det ger sig när jag väl orkar dra igång detta projekt.
Gällande att Innuos lägger in nischade funktioner så håller jag med dig till fullo. Kul!
Att nå DSD256/512 borde inte vara några problem, däremot finns det ju filter och inställningar som kommer få din burk att svettas lite... :winking:
mmm, det borde nog funka hyfsat, men jag vet faktiskt inte.... värt att testa iaf.
Jag har sett många som kör DSD512 på "endpoints" som "bara" har 100Mbit LAN så de borde inte vara några problem med en PhoenixNET i kedjan men man bör nog testa detta innan man ger sig ut i det allt för mycket. Jag testa precis min Statement i HQ Player läget och körde DSD256 utan problem (eller lite men de beror på att min dator är för klen helt enkelt) men DSD512 har ju den dubbla mängden i överföring så rätt väsentlig skillnad.
Då känns det ändå hoppfullt. Vad för dator testade du med att köra DSD256? Har nämligen också en MacBook Air M1 som ligger och samlar damm…
De är en gammal i3 3,5Ghz med 8GB RAM så allt för klen för högre DSD så de tog tid för den att starta uppspelningen av DSD256 men när den väl kom igång så var de inga problem att köra via nätverket som iofs. är 1Gbit fram till PhoenixNET (dator->switch->router->PhoenixNET->Statement) men som sagt de är ju Phoenixen som bestämmer överföringen iom. att den är 100Mbit. Att köra HQ Player är nog inget jag ämnar göra men som sagt de är bra att Innuos öppnar för flera sätt att använda sina produkter för de som vill.
Jag kommer nog inte heller köra den på heltid. Men jag vill ändå kunna bilda mig en egen uppfattning av vad allt surr om just Holo Audio May DAC ihop med HQ Player egentligen handlar om. Om inget annat så är jag några erfarenheter rikare.
  • 2 months later...
