Remove jitter. Restore balance.
Using a S/PDIF interconnect has one inherent problem - jitter. Jitter is the degradation of the audio signal when converting from analogue to digital and vice versa. It is the deviation in time from when an event should take place and when the event actually occurs. It causes issues with the conversion of the signal and can add digital interference.
After nearly four decades of research experience by our Chief Designer Thorsten Loesch, iFi audio has created an elegant and highly effective solution to eliminating jitter once and for all - the SPDIF iPurifier2.
The SPDIF iPurifier2 stamps out S/PDIF jitter, fully restores compromised signal integrity, rejuvenates sound quality, and creates increased warmth, depth and dynamic contrast. It challenges jitter on four levels:
1) Reclocks with the 10MHz Global Master Femto Clock
2) Regenerates with the full galvanic isolation of the source device from the DAC
3) Restores with the reduction of the ambient and power-related electromagnetic interference
4) Revitalises with the ultra-clean iPower supply
Link to post
