Transient Design Posted May 25, 2020 Posted May 25, 2020 (edited) Nu släpper iFi Audio sin helt nya version av iPhono! Samma låda, samma design (fast svart) men med helt nytt innehåll och klart högre prestanda. Edited May 25, 2020 by Transient Design Quote
Transient Design Posted May 25, 2020 Author Posted May 25, 2020 Just for the record iFi’s new iPhono3 Black Label phono stage is the perfect fix for vinyl addicts, ensuring every record is heard just as the artist intended. Southport, England – As music lovers across the land return to the tactile virtues of vinyl, so the demand for high-quality turntables has increased. This has raised the need for high-performance phono stages to make the most of the wonderfully natural and engaging sound of which vinyl records are capable. By necessity, every turntable has to be partnered with a phono stage to amplify the low-level output from the phono cartridge to ‘line level’. Some integrated amps and preamps have phono stages built in, but these vary in quality and are never as good as a well-designed offboard phono stage placed in the signal chain between the turntable and a line-level input on the amp. For serious turntable users, a separate phono stage is a must. Several years in development and incorporating technology derived from the £12,000 PH-77 phono preamplifier from sister-company AMR, iFi’s new flagship phono stage – the iPhono3 Black Label – has been painstakingly designed to satisfy the most discerning vinyl enthusiast. User-configurable to match any MC/MM cartridge and suit every record, it delivers performance and versatility that place it in a league of its own in the circa £1,000 category, competing with devices at much more rarefied prices. Quote
Transient Design Posted May 25, 2020 Author Posted May 25, 2020 Key features · Driven by iFi’s Class A TubeState engine and Direct Drive Servoless design · Wide range of settings – gain, load and EQ curves – to precisely suit the connected phono cartridge and the record being played · Ultra-low distortion and class-leading dynamic range · Super-low noise floor – one of the ‘quietest’ phono stages at any price, lets you hear every detail · High gain of 72dB on par with high-end phono stages at twice the price Quote
Transient Design Posted May 25, 2020 Author Posted May 25, 2020 (edited) Cable connections are at opposite ends of the slimline chassis – MM/MC inputs at one end, power in and audio out at the other. Edited May 25, 2020 by Transient Design Quote
Transient Design Posted May 25, 2020 Author Posted May 25, 2020 The direct approachUnlike a typical phono stage, the iPhono3 Black Label’s circuit is direct-coupled – that is to say, there is no coupling capacitor from cartridge to output. This is achieved without a conventional DC servo; iFi calls this design Direct Drive Servoless, incorporating a proprietary DC Infinity circuit to boosts DC gain to a level approaching infinity. Once the feedback loop is closed, the DC gain cancels all offset voltages to deliver a direct-coupled output with 0V DC offset. The key to the DC Infinity circuit is that it only changes the gain below approximately 0.01Hz, while leaving the AC behaviour of the circuit at higher frequencies unchanged, injecting neither noise nor distortion into the audio signal. This contributes greatly to the iPhono3 Black Label’s audible clarity, accuracy and transparency. Let the music flowIn the world of high-end audio, some folk advocate solid-state signal amplification while others swear by the sound of valves (or ‘tubes’ for those from the other side of the pond). Both have their inherent advantages – among them, solid-state circuits typically offer lower distortion and high durability, while valves deliver fluid, grain-free sound with natural tonality. At the iPhono3 Black Label’s heart lies iFi’s third generation TubeState engine, the result of four decades of research into valve and transistor technology by the company’s Technical Director, Thorsten Loesch. TubeState is solid-state circuitry designed to capture the key attributes that make valve circuits so sonically appealing whilst maintaining ultra-low distortion. Specialised JFET op-amps combine with a Class A buffer circuit featuring hand-matched PNP bibolar transistors; the buffer circuit minimises the loading of the amplifier circuit and biases the output stage into single-ended Class A. High input impedance approaches the ‘zero loading’ a valve grid provides, with excellent drive ability and vanishingly low THD (Total Harmonic Distortion). The TubeState engine delivers a sound of exceptional poise – crystalline clarity without a hint of edginess; free-breathing dynamics; engaging pace and timing; and a soundstage brimming with texture and fine detail. From the moment the needle hits the record, everything sounds crisp and clear, yet no single element within the musical whole is over-emphasised – you hear the music, cohesive and in its entirety, as it was intended to be heard. Quote
Transient Design Posted May 25, 2020 Author Posted May 25, 2020 Sonic tailoring to suit you, sirMany phono stages offer nothing in the way of adjustment to tailor performance to suit a specific system or record, save perhaps switching between MM and MC cartridge types. Some supply settings to match the electrical characteristics of individual cartridges. But very few offer the sheer range of adjustment provided by the iPhono3 Black Label, enabling a vinyl enthusiast to tailor the performance to precisely match his or her phono cartridge and record collection. A series of DIP switches on the underside of the unit enable gain and load to be set – essential to wring the very best performance from a high-performance cartridge. Gain can be adjusted between 36dB and 72dB, alongside a wide variety of load values – eight for MC cartridges and a further five for MM cartridges. Spending a little time to set up the ideal combination to match the cartridge on your turntable delivers great sonic reward – iFi has created an online ‘cartridge calculator’ to assist with this. The iPhono3 Black Label is not only great at pairing perfectly with your cartridge; you can also tailor the sound to match specific records in your collection, thanks to a variety of precisely engineered EQ curves. Some brief background: in 1954, a few years after the birth of the LP format, the Record Industry Association of America (RIAA) promulgated the use of a specific equalisation curve to standardise the sound and playing time of LP records. While RIAA equalisation was widely adopted in America, different EQ curves were still being applied by record labels in other countries two decades later. By the late 1970s most European labels had adopted RIAA equalization and by the 1980s it had become the de facto global standard, with just a handful of Asian and Eastern European labels sticking to other EQ curves until the end of the decade. A toggle switch at one end of the iPhono3 Black Label allows the user to select between three EQ curves: RIAA, Columbia and Decca. It can generally be assumed that LPs produced from 1980 onwards were made using RIAA equalisation, which means they should sound best with the RIAA setting engaged. But records released before1980 may have been made using different equalisation and may sound better with the Columbia or Decca EQ curve engaged. This applies not only to records released by those specific labels. For example, many of Deutsche Grammophon’s classical records released before 1980 can sound dry and flat – this is because they were produced using the Decca EQ curve and very few phono stages provide this option, but with the correct EQ applied they sound superb. As a general rule, if an LP sounds thin and edgy with the RIAA EQ, try the Decca EQ curve; if it sounds overly bright with overblown bass, try the Columbia setting. But that’s not all! Further DIP switches on the underside allow the RIAA EQ setting to be further tuned to taste. Users can choose the standard RIAA curve – applied with +/- 0.2dB accuracy – or an enhanced version called ‘eRIAA’ offering extended high-frequency response. Alternatively, if the user has problems with warped records, which can cause a large signal output in the subsonic region, the IEC setting takes the standard RIAA curve and applies a subsonic filter to tackle the issue. Finally, the eRIAA+IEC setting applies the subsonic filter to the enhanced RIAA curve. Quote
Transient Design Posted May 25, 2020 Author Posted May 25, 2020 Sum of the partsiFi has utilised components of uncompromising quality throughout the iPhono3 Black Label’s circuit design. For example: Burr-Brown SoundPlus op-amp, complemented by Panasonic ECPU film capacitors, delivers vanishingly low distortion and ensures excellent dynamic range. Computer-matched pair of planar high-gain bipolar input transistors lowers output noise. Four Nichicon 470uF/6.3V capacitors deliver lower ESR (Equivalent Series Resistance) and improve speed and bass performance. Eight Panasonic OS-CON capacitors totalling 14,800uF deliver low ESR, excellent noise reduction and exemplary frequency characteristics. Numerous TDK C0G type capacitors – these have lower thermal drift and distortion than Polystyrene capacitors. Two Elna Silmic II capacitors for the power supply – these use silk fibre paper for the isolating barrier, resulting in decreased odd-order distortion and reduced microphonics. Numerous Vishay MELF thin film resistors, delivering dramatically reduced distortion compared to standard surface-mounted resistors. The iPhono3 Black Label comes with the 15V version of iFi’s new iPower X ultra-low-noise AC/DC power supply (£99 when purchased separately). This delivers an exceptionally low noise floor and contributes significantly to the phono stage’s class-leading performance. The ideal phono stage for passionate vinylphiles looking to unlock the true sound of their LP collections, the iFi iPhono3 Black Label is available from selected retailers from tomorrow at an RRP of £999 (€1099, $999). Quote
Transient Design Posted May 25, 2020 Author Posted May 25, 2020 Pris i Sverige med Svensk moms och Euro kring 10,8 i växelkurs så kommer den att landa på ca 12 000kr till kund. Inte i lager ännu men på väg inom kort. Quote
Transient Design Posted June 16, 2020 Author Posted June 16, 2020 Nu finns iPhono3 Black Label på lager i Sverige! Quote
Transient Design Posted August 24, 2020 Author Posted August 24, 2020 Första testet ute av iPhono3 Black Label! September utgåvan av Hifi-World säger följande: OUTSTANDING - amongst the best VALUE - keenly priced VERDICT Superb sound quality distinguishes this phono preamplifier. FOR - spacious, dynamic sound - no hiss - adjustability AGAINST - fiddly DIP switches - obscure case graphics - mechanically awkward Quote
Transient Design Posted August 24, 2020 Author Posted August 24, 2020 (edited) Citat från testen: "The iPhono barged up to 9 pretty fast! Not only did it have stage depth and an organic quality that made humans sound human, but there was no hiss – none. I have never heard an MC preamp so quiet, even with full volume applied. Across a broad range of LPs the iPhono3 maintained its sense of sonic poise, with no top end sharpness, a wonderfully clear midband and an almost honey sweet analogue quality. There was no forced detail, just great natural insight,..." Edited August 24, 2020 by Transient Design Quote
Transient Design Posted August 24, 2020 Author Posted August 24, 2020 Citat från test-mätningarna: Noise (equivalent input noise,or e.i.n.) measured 0.04μV which is extremely low, making this a super-quiet preamplifier suitable for the lowest output MC cartridges. Frequency response 20Hz-20kHz Separation 68dBNoise (e.i.n.) 0.04μV Distortion 0.1% Gain (MM, MC) 48dB /72dB Quote
Transient Design Posted August 24, 2020 Author Posted August 24, 2020 Quite obvious was good stage depth, a nice sense of silence and a big bodied sound more reminiscent of valves than transistors Quote
Transient Design Posted September 2, 2020 Author Posted September 2, 2020 Ny test ute av iPhono3 BL: Och den viktigaste av alla, den av Michael Fremer: Rubriken tror jag säger det mesta...? iFi's iPhono 3 MM/MC Phono Preamplifier Takes A Giant Sonic Leap Forward https://www.analogplanet.com/content/ifis-iphono-3-mmmc-phono-preamplifier-takes-giant-sonic-leap-forward-0 Conclusion IFi’s iPhono 3 is a major achievement in phono preamplification in terms of its adjustability, high gain and low distortion and low noise. If you own an iPhono 2 and love it, sell it and buy an iPhono 3. It’s that much better. The improvement isn’t incremental. It’s a major step forward. Under the previous reviews readers asked how the iPhono 2 compared to other products at a similar price point. This gets too difficult for a reviewer to cover. There are many choices at around $1000 including some reviewed on this site, but comparing all of them is nearly impossible so I’m not going to compare this one to any of those. I’ll just conclude by writing that if you’ve got $1000 to spend on a fully adjustable, compact, MM/MC phono preamplifier I don’t see how you can possibly buy an iPhono 3 and regret your decision. The low noise floor alone makes it an exceptional product. Add the low distortion, the exacting transient response and the unit’s superb ability to delineate subtle microdynamic gradations, plus its impressive transparency and you can complete the sentence. shaft 1 Quote
