figge Posted June 5, 2021 Author Share Posted June 5, 2021 54 minutes ago, P-pan said: Lite grejer från Ica på väg in för tillagning, måste bara hämta i nästa vecka. Lite beroende på hur hungrig jag kommer att vara. Asså, kom igen här va... ??? Lugn, mat och vin har jag fått, sitter och väntar på avec. Var är serveringspersonalen?😂 Quote Link to comment Share on other sites More sharing options...
figge Posted June 5, 2021 Author Share Posted June 5, 2021 11 minutes ago, byZan said: Ja det är jobbigt att hållas på halster /byZan Du får vänta till måndag eller i värsta fall tisdag, beroende på sagda mobilitet.😉 Quote Link to comment Share on other sites More sharing options...
figge Posted June 8, 2021 Author Share Posted June 8, 2021 Bud på väg, leverans på em. VoicesInMyHead and byZan 2 Quote Link to comment Share on other sites More sharing options...
figge Posted June 8, 2021 Author Share Posted June 8, 2021 parsifal 1 Quote Link to comment Share on other sites More sharing options...
figge Posted June 8, 2021 Author Share Posted June 8, 2021 Bränner väl av en till då. Quote Link to comment Share on other sites More sharing options...
triomio Posted June 8, 2021 Share Posted June 8, 2021 Kan det vara en DAC? Quote Link to comment Share on other sites More sharing options...
LPL Posted June 8, 2021 Share Posted June 8, 2021 En grov XLR, en PSU? Quote Link to comment Share on other sites More sharing options...
YYZ Posted June 8, 2021 Share Posted June 8, 2021 Kanske en KECES SPhono RIAA Quote Link to comment Share on other sites More sharing options...
figge Posted June 8, 2021 Author Share Posted June 8, 2021 39 minutes ago, YYZ said: Kanske en KECES SPhono RIAA Örnblick? Eller har du snappat upp det någon annanstans? Quote Link to comment Share on other sites More sharing options...
P-pan Posted June 8, 2021 Share Posted June 8, 2021 2 hours ago, figge said: Örnblick? Eller har du snappat upp det någon annanstans? För hög sommarvärme för vissa...tror jag... YYZ 1 Quote Link to comment Share on other sites More sharing options...
figge Posted June 8, 2021 Author Share Posted June 8, 2021 2 minutes ago, P-pan said: För hög sommarvärme för vissa...tror jag... Blir så när man kör med Klass A.🤔 Får se till att ha kylvätska redo. P-pan 1 Quote Link to comment Share on other sites More sharing options...
figge Posted June 9, 2021 Author Share Posted June 9, 2021 Morgonens session startad. Quote Link to comment Share on other sites More sharing options...
figge Posted June 10, 2021 Author Share Posted June 10, 2021 Lite paus i testandet, återkommer på lördag. Ampalang and Josaa 2 Quote Link to comment Share on other sites More sharing options...
figge Posted June 11, 2021 Author Share Posted June 11, 2021 Nu får vi lägga ner för idag, grannen börjar slå i skåpluckorna på andra sidan väggen. Just kidding. Det börjar hända lite nu, högen av skivor växer. Ranefjord, Daniel and AlfaGTV 3 Quote Link to comment Share on other sites More sharing options...
AlfaGTV Posted June 12, 2021 Share Posted June 12, 2021 Man kan nästan ana att du lärt av de bästa när det gäller att dra på återrapporteringen! Nåt kan du väl säga, även om grejerna är nya fortfarande? Quote Link to comment Share on other sites More sharing options...
figge Posted June 12, 2021 Author Share Posted June 12, 2021 21 minutes ago, AlfaGTV said: Man kan nästan ana att du lärt av de bästa när det gäller att dra på återrapporteringen! Nåt kan du väl säga, även om grejerna är nya fortfarande? Absolut, som sagt tagit lärdom av de gamla uvarna här på Forumet. Först och främst helt tyst vilket inte är negativt när det gäller vinylavspelning. Väldigt öppen och fin ljudbild, kanske lite mer drag i botten, fortfarande lite edgig i toppen. Som en oslipad diamant. Testade med att höja gain igår vet inte riktigt blev så bra. Åter till grundinställningen nu. Dagens session startad, innan frun är tillbaka. En frontbild kanske? byZan, AlfaGTV, calm and 3 others 6 Quote Link to comment Share on other sites More sharing options...
AlfaGTV Posted June 12, 2021 Share Posted June 12, 2021 Ser trevliga ut, men jag fattar inte riktigt ändå. Är det två dedikerade MM och två dedikerade MC ingångar alltså? Vet du vad det är för gain förresten? Quote Link to comment Share on other sites More sharing options...
figge Posted June 12, 2021 Author Share Posted June 12, 2021 Ja, två av varje. Sphono spec 40dB/46dB for MM, 60dB/66dB for MC. AlfaGTV 1 Quote Link to comment Share on other sites More sharing options...
triomio Posted June 12, 2021 Share Posted June 12, 2021 32 minutes ago, figge said: Ja, två av varje. Som gjord för att skaffa en spelare med 4 tonarmar då ..eller 4 spelare? byZan 1 Quote Link to comment Share on other sites More sharing options...
figge Posted June 12, 2021 Author Share Posted June 12, 2021 Hittade en svensk beskrivning av Sphono KeCeS referens-RIAA, en rigtig tungviktare ¤ Fristående linjär nätdel av högsta kvalitet för att eliminera störningar. (Ephono Power). ¤ separata +/-45 Volt och 15 Volts matningar ¤ Nätdelen har överhettningsskydd (OTP) ¤ Dual monouppbyggd. ¤ Fyra individuellt inställbara ingångar (2st MM + 2st MC) ¤ Balanserade och obalanserade (RCA) utgångar. ¤ Förgyllda kontakter av högsta kvalitet. ¤ Subsonicfilter. ¤ 40db MM gain och 0 rep +6dB gainval. ¤ Valbar impedans i MC läge: 56/100/220/470/1K2/47K ohm. för att matcha flertalet pickuper och i MM 47k ohm. ¤ Valbar kapacitans i MM-läge: 47/100/150/220/330/470 PF ¤ RIAA-korrektion noggrann inom två tiondels dB. ¤ Kvalitetskomponenter, bla. Wimakondingar ¤ Chassilådorna är byggd av 4mm tjock aluminium för att effektivt blockera EMI/RFI störningar. Specification Frequency Response : 20-20Khz THD: MM <0.002%, MC <0.09%. S/N Ratio: MM 96dB A-weighted, MC 82dB A-weighted. Input Impedance: MM 47k ohm, MC variable 56/100/220/470/1K2/47K ohm. Input Capacitance: MC 100PF, MM 47/100/150/220/330/470PF. Gain: 40dB/46dB for MM, 60dB/66dB for MC. Power In: DC +- 48V and +15V (Power by Sphono Power). Låda: 4mm Aluminum Dimension (WxDxH): 300x220x66mm Weight: 3.5KG Sphono Power Specification AC Input Voltage: 110V-120V, 60Hz / 220V-240V, 50Hz (Switchable). DC output Voltage: DC +- 48V and +15V. Power Consumption: 18 Watts Casing: 4mm Aluminum Dimension (WxDxH): 300x220x66mm Weight: 5KG Quote Link to comment Share on other sites More sharing options...
figge Posted June 12, 2021 Author Share Posted June 12, 2021 1 hour ago, triomio said: Som gjord för att skaffa en spelare med 4 tonarmar då ..eller 4 spelare? Någon som behöver avveckla någon av sina egna? triomio 1 Quote Link to comment Share on other sites More sharing options...
AlfaGTV Posted June 12, 2021 Share Posted June 12, 2021 2 hours ago, figge said: Någon som behöver avveckla någon av sina egna? Tänkte du på "någon" speciellt? JWE and byZan 2 Quote Link to comment Share on other sites More sharing options...
figge Posted June 12, 2021 Author Share Posted June 12, 2021 En liten summering av dagens lyssning, frun kom precis genom dörren.😂 Det var länge sedan jag fick dessa två presenteras på så trevlig sätt. lindome and torbjorn 2 Quote Link to comment Share on other sites More sharing options...
figge Posted June 12, 2021 Author Share Posted June 12, 2021 2 hours ago, AlfaGTV said: Tänkte du på "någon" speciellt? Ingen nämnd ingen glömd.😉 Quote Link to comment Share on other sites More sharing options...
figge Posted June 12, 2021 Author Share Posted June 12, 2021 Nu efter 12 veckors egenpåtagen frånvaro av vinyllyssning uppskattar jag verkligen den, nu när jag spelar Roon.🙏 Quote Link to comment Share on other sites More sharing options...
figge Posted June 12, 2021 Author Share Posted June 12, 2021 2 hours ago, figge said: Ingen nämnd ingen glömd.😉 Kanske någon annan som vill passa på att erkänna att vederbörande sitter på mer än en vinylspelare?🤔 Quote Link to comment Share on other sites More sharing options...
conan Posted June 13, 2021 Share Posted June 13, 2021 Frestande att handla en till svarv. Ligger en Lyra Argo och har det tråkigt i ett skåp. 😏 Quote Link to comment Share on other sites More sharing options...
figge Posted June 14, 2021 Author Share Posted June 14, 2021 Ett steg närmare ett erkännande. Ström påkopplat på Trilogy, får nog stå tills imorgon. Lite ångest inför att få höra hur det var innan Keces. Quote Link to comment Share on other sites More sharing options...
VoicesInMyHead Posted June 14, 2021 Share Posted June 14, 2021 funderar du på att testa något annat också eller föll du pladask för Keces? Quote Link to comment Share on other sites More sharing options...
figge Posted June 14, 2021 Author Share Posted June 14, 2021 4 minutes ago, VoicesInMyHead said: funderar du på att testa något annat också eller föll du pladask för Keces? Det var det här som gjorde mig intresserad. ”De har hittat ett Riaa-steg för 29000kr från Taiwan som de menar spelar mycket nära deras 150.000kr Whest-Riaa. Det är inte hela vägen dit men mycket nära. Keces S.Phono var namnet och så här ser den ut.” Just nu efter några timmar så är nog lite pladask, har hänt ”ganska” mycket de senaste 10 timmarna av inspelningen. Tro inte på de personer som säger att det inte har någon betydelse. VoicesInMyHead, LPL and Perfect sense 3 Quote Link to comment Share on other sites More sharing options...
