Engelholm Audio Posted July 2, 2017 Posted July 2, 2017 (edited) Sommar-rea och ny plats måste göras inför höstens modeller. Alla är demo-ex och bra skick. 1års garanti. Engelholm Audio Leto, valnöt/vit 9'900 (ord pris 24'900) Engelholm Audio Trill, ek/vit 19'900 (ordpris 59'900) Engelholm Audio Hades, valnöt/svart 8'900 (ord pris 24'900) 1a ordningens filter, otrolig spridning, homogent ljud. Quote Leto is a carefully tuned stand mount speaker with a 1st order crossover. The crossover is hand built and uses only one component in the signal path to each driver for the filtering. This, of course, puts high demands on the drivers behavior over a much wider frequency range. This is solved by using drivers that benefit from Diecast Aluminum Chassis which is vented below spider for better power handling and better sound. The precision textile dome and copper clad center pole which yields a very low voice coil inductance. The tweeters dome is optimized for ultra high frequency cut-off which guarantees perfect dispersion pattern. Trill: Quote using drivers that benefit from Diecast Aluminum Chassis which is vented below the spider for better power handling and better sound. The precision textile dome and copper clad center pole which yields a very low voice coil inductance. Topptestad av bland annat Image Hifi: http://www.engelholmaudio.com/bilder/imagehifi-trill-2013.pdf Edited December 2, 2017 by Engelholm Audio Lägre priser! Sålt. Quote
