marcus_ec Posted May 4, 2015 Posted May 4, 2015 (edited) Skickas ej 40kg.. Specifications High Current Dual Mono Fully Balanced Power Amplifier. 2000VA toroidal transformer. A total of 180 000 uF electrolytes in the power supply. Dual set of speaker terminals for each channel. Balanced (RCA) and Unbalanced (XLR) inputs. Input impedance: 15kohm, RCA and XLR Output Power (both channels driven): 2x250W 8ohms load 20Hz-20Khz; 2x400W 4ohms load 20Hz-20KHz THD+N: below 0.05% in both cases. THD+N: 1kHz, 250W, 8 ohm load below 0.01%. Frequency response: 20Hz-100kHz –0.5dB Noise: below –100dBV Gain: 26dB unbalanced, 20dB balanced. Trigger input range: 4-15V Colour options: Black or Titanium Weight: 40kg Dimensions: W 430mm x D 546mm x H 216mm (With Feet) 25.000:- eller ge ett bud Kan levereras med bil onsdag ner mot malmöhållet. Bilder Edited May 4, 2015 by marcus_ec Quote
