crion Posted January 18, 2015 Posted January 18, 2015 (edited) Shunyata Hydra Triton är en erkänd referensströmrenare använd i både kända studios och i Hi-Fi referenssystem. Det unika med denna strömrenare är att den även klarar tunga slutsteg utan att limitera dynamik, snarare öppnar den upp reserverna samtidigt som tystnaden i systemet ökar, m.a.o. positiv inverkan på S/N förhållande. Den är verkligen en klockren grundbyggsten i din Hi-Fi setup. The HYDRA TRITON power distributor is the beneficiary of a ten year research and development cycle aimed at perfecting high-performance, maximum current power-distribution for the film, recording and audio/video industries. All of the unique technologies within HYDRA TRITON are the exclusive intellectual property of Shunyata Research scientist Caelin Gabriel. It is rare in any product category - even less so in power products, for there to be a consensus on products used in different systems and within differing contexts. HYDRA TRITON has broken that mold by offering reference performance in every recording, film, media and music system they have been applied in since their debut. TRITON models are now being used in many of the finest recording studios; by top electronics manufacturers and industry luminaries the world over. This critical and commercial consensus is the result of Shunyata’s ability to measurably improve peak-current delivery to electronics using DTCD Analysis. Equally important has been the development of the MPDA (Multi-Phase-Differentail-Array) filter-networks, which minimize CCI (Component-to-Component Interference) without adding any capacitive or inductive reactance. Shunyata’s (patents pending) Noise Isolation Chambers add performance to the TRITON design by passively absorbing noise in the megahertz and gigahertz region. Shunyata’s ZPP-DS (Zero-Point Power Distribution Buss) and VTX wiring significantly minimize electrical resistance and wire-related distortions. Taken as a whole, the HYDRA TRITON combines true technical innovation and custom parts engineering to deliver what can be considered by any standard, the finest product in its category. NIC NICs (noise isolation chambers) are patented devices that reduce very high frequency noise in the Megahertz to Gigahertz range without the current limiting and negative sonic affects associated with the use of conventional transformers, coils and ferrite beads. MPDA Filter The MPDA (multi-phase differential array) is an advanced 30 element, surface mount, filter array that significantly reduces power-line noise without the audible or visible side-effects normally associated with conventional capacitive and inductive approaches. ZPP-DS ZPP-DS (Zero-Point Power Distribution System) significantly reduces the number of wires and connection points within the power distribution system. The A.C. outlet contacts and main electrical buss system are unified into a single electrical point of contact, while eliminating the daisy-chained runs of wiring needed in conventional distribution systems. VTX Geometry Conductors Shunyata Research has developed what might be the world's perfect power conductor geometry. VTX wire geometry simulates a hollow conductor, which minimizes inherent inductive reactance and skin effect, improving DTCD™ instantaneous current propagation. MAXIMUM VOLTAGE - Max Voltage (Euro): 240VAC unregulated CURRENT RATINGS - Max continuous current: 16 Amps (EU) - Peak instantaneous current: >200 Amps (800ms) SURGE SUPPRESSION - Max surge current: 40,000 Amps (8 / 50ms) NOISE REDUCTION TECHNOLOGY - 1 x MPDA (multi-phase differential array) - NIC (Noise Isolation Chambers) - Patented (ZrCa ferroelectric compound) - Volume: 11,935mm2 (50.8 x 234.95mm) - Hot and neutral and ground NICs OVER CURRENT PROTECTION - Hydraulic electromagnetic breaker CONNECTORS - Inlet: IEC-C20 - Euro Outlets: 10 Outlets (EU1-16R) NOTE: They Hydra Triton requires a power cord with a C19 connector which is not included with the product. WIRING / BUSS SYSTEM - ZP-PDS Dual Solid Brass Buss System - 9 AWG Shunyata VTX Conductors - CDA-101 Copper - Shunyata's Alpha Cryogenic Treatment CONSTRUCTION - 16 Gauge Powder Coated Steel Chassis - Aluminum Faceplate - Vibration Isolation Treatment - Shunyata's Isolation Footer DIMENSIONS Width: 17.25 inches (43.8 cm) Depth: 16.50 inches (41.9 cm) Height: 5.75 inches (14.6 cm) Weight: 38 lbs (16.4 kg) Edited March 16, 2015 by crion Quote
crion Posted January 21, 2015 Author Posted January 21, 2015 Passar perfekt med Shunyata Anaconda Zitron C19. http://www.euphonia-audioforum.se/forums/i...showtopic=11220 Quote
