crion Posted September 21, 2014 Posted September 21, 2014 (edited) Shunyata Anaconda Zitron är förmodligen den mest kända referensströmkabeln. Denna modell är den senaste 2014 versionen för Svenskt Schuko vägguttag samt C19 IEC (stora slutsteg, strömrenare). Jag har kört den från vägg in i både Shunyata Hydra Triton och Hydra Talos strömrenare med utmärkt resultat. Men även stora referensslutsteg och andra referensströmrenare passar denna stömkabel utmärkt till. Shunyata Anaconda Zitron The Anaconda model represents Shunyata Research's reference for design, measurement and test purposes. Outside of the world's most celebrated professional music studios and the most finely calibrated sound and music systems, the Anaconda represents only the promise of what is possible at the outer-reaches of the technology. The Anaconda holds a place as a reference-point for the industry, not as commercial success but as a product with no compromise and a single purpose; to showcase the startling performance effects of a technology fully realized. The Anaconda uses VTX (hollow-core wire geometry) conductors. The new AC connectors are developed with pure copper, the CDA-101 CopperConn. APPLICATIONS Due to theAnaconda's top of the product range cost and performance, it must be considered an exclusive product for only the world's finest professional, critical and consumer systems. TheAnaconda will offer dramatic performance improvements used with literally any system component. Even a single seven-gauge Anaconda placed on a critical source component, amplifier, Hydra or other power distributor will deliver an increase in dynamics, low-level resolution and clarity the likes of which no other power cord or exotic power conditioners can offer. VTX Geometry Conductors Shunyata Research has developed what might be the world's perfect power conductor geometry. VTX wire geometry simulates a hollow conductor, which minimizes inherent inductive reactance and skin effect, improving DTCD instantaneous current propagation. CDA-101 Copper CDA 101 copper is the highest purity copper on the metals market. It comes with papers that prove its authenticity. This is the only type of copper that Shunyata Research uses in its electrical products, from signal cables to power cords and power conditioners. ALPHA CRYO Process Shunyata Research cryogenically treats all wire and electrical contacts used in the production of its signal cables. A state-of-the-art computer controlled chamber is used to lower the temperature of the contents to -320 degrees fahrenheit. The exclusive, Shunyata Research developed, Alpha Cryogenic Process uses a proprietary combination of gases to enhance the cryogenic treatment. SHUNYATA CopperCONN™ CONNECTORS Pure Tellurium Copper Base Metal Superior Contact Grip Alpha Cryogenic Treated Anaconda Zitron Specs FEATURES CopperCONN™ CONNECTORS AC & IEC connectors CDA-101 cryogenic copper conductors Unrivaled Shunyata Research Craftsmanship 7 AWG Coincident Concentric Conductors VTX Geometry MAINS CONNECTORS Schuko (EURO) STANDARD LENGTH - 6.0 feet (1.75M) Produktionsår: 2014 Edited February 25, 2015 by crion Quote
crion Posted October 15, 2014 Author Posted October 15, 2014 Då har en av tre blivit sålda. Två kvar! Quote
crion Posted November 5, 2014 Author Posted November 5, 2014 Då är två av tre sålda, en kvar! Tveka inte på denna referensströmkabel, för det här priset hittar du ingenting bättre! Quote
crion Posted January 21, 2015 Author Posted January 21, 2015 (edited) Musicerar fantastiskt bra med den fina Shunyata Hydra Triton Strömrenaren också i Säljes. http://www.euphonia-audioforum.se/forums/i...showtopic=11401 Edited January 21, 2015 by crion Quote
