Lyra Aaaaaaaaatlas!
Lyra Atlas specifikationer
Konstruktör: Jonathan Carr
Byggare: Yoshinori Mishima
Typ: Medium weight, medium compliance, low-impedance moving coil cartridge
Nål: Lyra-designed long-footprint variable-radius line-contact nude diamond (3µm x 70µm), slot-mounted
Nålarmssystem: Diamond-coated solid boron rod with short one-point wire suspension, directly mounted into cartridge body via high-pressure knife-edge system
Spolar: 2-layer deep, 6N high-purity copper, cross-shaped chemically-purified high-purity iron former, 4.2ohm self-impedance, 11µH inductance
Utspänning: 0.56mV@5cm/sec., zero to peak, 45 degrees (CBS test record, other test records may alter results)
Frekvensomfång: 10Hz ~ 50kHz
Kanalseparation: 35dB or better at 1kHz
Komplians: Approx. 12 x 10-6cm/dyne at 100Hz
VTA: 20 degrees
Pickuphus: One-piece machining from solid titanium billet, with reduced-surface higher-pressure headshell contact area, predominately non-parallel and asymmetrical shaping, phase-interference resonance-controlling mechanism, and body threaded directly for mounting screws
Monteringsskruvar: 2.6mm 0.45 pitch JIS standard
Avstånd mellan monteringshål och nålspets: 9.5mm
Pickupvikt (exkl nålskydd): 11.6g
Rekommenderat nåltryck: 1.65 ~ 1.75g (1.72g recommended)
Rekommenderad last direkt till MC phono input: 104ohm ~ 887ohm (determine by listening, or follow detailed guidelines in user manual)
Rekommenderad last via step-up transformer: 5 ~ 15ohm (step-up transformer's output must be connected to 10kohm ~ 47kohm MM-level RIAA input, preferably via short, low-capacitance cable)
Rekommenderade tonarmar: High-quality pivoted or linear (tangential) tonearms with rigid bearing(s), adjustable anti-skating force, preferably VTA adjustment
Share this post
Link to post
Hoppsan! En galet trevlig puppa för mina öron! Priset är väl iofs också nästan galet men jag tror ändå att man tar vinylspelandet så långt det går, med reservation för att man kan gilla lite annorlunda ljudsignaturer då.
Önskar dig många, långa timmar vinylnjutande!
Share this post
Link to post
Satan i gatan.
Undrar om jag ens vågat hålla i en sån. Än mindre montera....
Grattis!!
Det måste ju innebära att din gamla är till salu för en halv spottstyver? :D
Share this post
Link to post
Jojo, endast det bästa är gott nog!:mm::thumbsup:
Hörde den på mässan i Stockholm tidigare i år. Förstod att den görs i två varianter men förstod aldrig skillnaden. I vart fall en fantastisk pickup!
Grattis!
calle_jr likes this
Share this post
Link to post
Etna och Atlas görs även i en SL-modell med lägre utspänning och lägre internimpedans. Antar att massan också är lägre.
Share this post
Link to post
Lyra gör så kallade SL-versioner med färre lindningar. Man får en extremt låg internimpedans, men en ganska mager output. För Atlas blir output halverad.
Share this post
Link to post
4 hours ago, calle_jr said:
Lyra Audio döper sina pickuper efter storheter i den grekiska mytologin. Och Atlas var ju den som bar upp världsalltet, en slags titanernas titan;
En dröm mindre...
Lyssning med Atlas tarvar näst intill en ny klädkod än vad du normalt nyttjar. En arm och puppa för lyssning i vardagsstassen kan ju vara ett lämpligt komplement. ;)
Share this post
Link to post
Misstänker nästan synkronisering här. På samma minut.
Tur ni sa samma. :D
Share this post
Link to post
21 minutes ago, Bebop said:
En dröm mindre...
Hazmat-dräkt eller frack och fluga? :D
Grattis @calle_jr!
calle_jr likes this
Share this post
Link to post
Ja nu minns jag att man pratade om olika lindningar i puppan.
En intressant detalj i sammanhanget är den förhållandevis modesta förpackningen på en så pass dyr produkt. Gillar producenter som lägger fokus på rätt saker och inte flashiga träboxar och annat fördyrande förpackningsmaterial. Däremot kan det gedigna nålskyddet vara en bra detalj i sammanhanget så man kan undvika "små mekanikers flinka fingrar" Vill minnas att en nål fick skatta till förgängelsen vid småbarnsbesök? Kanske dags att se över försäkringsskyddet? Kollade mitt eget vid senaste puppaförvärvet och det täcktes av drullemomentet. Men då pratar vi kanske halva kostnaden för den puppan.
Skall bli kul att få dina lyssningsintryck så småningom. Tarvar väl lite inkörning, misstänker jag.
calle_jr likes this
Share this post
Link to post
8 hours ago, Taxmannen said:
Jag hoppas verkligen att du delar med dig av dina tankar och funderingar om varför du landade på just denna juvel!?
8 hours ago, tek said:
Roligt med ny pickup, vad förväntar du dig för förbättringar?
Enkelt uttryckt; Vad gör Lyra Atlas som inte Kleos kan göra? Det vill jag utröna i hemmiljö.
Varje konstruktion är en samling kompromisser. Jonathan Carr har spenderat ett arbetsår på att gå igenom varje detalj i generatorn för vad som skulle bli Lyra Atlas, från magneternas komposition (han verkar helt nednördad på BH-kurvor och ovanliga magneter) till infästningen av upphängningstråden till nålarmen. Lösningen med rak komplians och dämpning under spelning kommer från detta arbete, och här har han satt två dämpare - en bakre och en främre elastomer. Hans kanske största fokus för Atlas har varit att hitta olika lösningar att ta hand om överförd vibrationsenergi så att den inte påverkar generatorn. Vi lär återkomma till det. Han har konstruerat ett ankarblock i pickuphuset för att kunna direktmontera armaturen med rätt uppspänning. I bilden nedan ser man bakänden på infästningen av armaturen, den lilla svarta flärpen.
Det jag förväntar mig är att uppleva vad detta omfattande arbete har resulterat i ljudmässigt.
Richard, Taxmannen and Kilgore like this
Share this post
Link to post
Spännande nyförvärv!
Jag väntar spänt på lyssningsintryck. Blocket som allt sitter i ser stabilt ut och redan där skapas förutsättningar för något bra och Lyra verkar vara genomtänkta konstruktioner så jag förväntar mig förstås Lyriska omdömen.
calle_jr likes this
Share this post
Link to post
Hazmat är inte att rekommendera :D
Bara att packa upp den utan risk krävde shorts, slimfit t-shirt, glasögon av och stöd för handen. Jag kör vidare med det nu denna hemska årstid.
JWE likes this
Share this post
Link to post
Grattis Calle.
Jag gjorde ett liknande "resa" då jag gick från en puppa i samma prisläge som Kleos (en EMT-ti) till en Etna. Min upplevelse var att jag gick från en underbar "närvaro" till magisk "härvaro". Lyra Etna bjuder på så mycket rumsinformation och mikrodetaljer att jag flyttades rakt in i inspelningen. Orkestern var helt enkelt "här" hemma hos mig och spelade. Musiken får en nerv som är tungt beroendeframkallande.
Och Atlas kan göra fler saker som inte Kleos kan i samma utsträckning. Som t ex få spargrisen att se lätt anorektisk ut och vuxna män att plötsligt känna sig väldigt darrhänta :D.
Men jag tycker att det är värt det - hoppas du upplever det samma.
calle_jr likes this
Share this post
Link to post
Ojojoj! Grattis. Så himla roligt. :)
Det där blir bra. Valet är nog klockrent. Efter att jag hört Etna hos Bigblue så är det svårt att inte tänka åt det hållet. Det är min plan att framöver hamna "däromkring" också om gudarna vill mig väl. Skall bli mycket roligt att höra vad du tycker.
calle_jr likes this
Share this post
Link to post
Please sign in to comment
You will be able to leave a comment after signing in
Sign In Now
Sign in to follow this
